e99 Dorman up pipes ????? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-26-2014, 09:14 AM Thread Starter
I have an e99 f350 and on the hunt for some new up-pipes that are not the crazy expensive international pipes. I contacted Dorman about the below pipes and the rep said they will work on the early 99 7.3 diesel. But I noticed in the description it says 99-03 which means I dont think it will work. Anybody know for sure??
Dorman Products - Search Results
mustninty is offline
post #2 of 11 Old 02-26-2014, 01:32 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
99-03 means late 99 not early 99.
there was a set of internatonal up pipes for 400 on ebay for an e99...thats less than i paid for my late 99 ones.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #3 of 11 Old 03-20-2014, 05:02 PM
Thought I saw some at riff raff less than IH
Dorsal is offline
post #4 of 11 Old 03-20-2014, 05:36 PM
c69ss396's Avatar
Riffraff Diesel Bellowed Up-pipe Kit 94-Early 99 - Riffraff Diesel Performance
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 11 Old 03-27-2014, 03:54 AM
look at the date. it says Application Notes:
V8 445 7.3L; From 12/6/98
Superduty is offline
post #6 of 11 Old 03-27-2014, 09:21 AM
timmyboy76's Avatar
the dormans will not work. Buddy just installed a set with motor out, and him being a fabricator, HAD TO cut a section out of each, reweld, and then proceeded to install....
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 11 Old 02-21-2015, 06:09 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
But if you cut out (shorten) the dorman bellowed up pipes for a late motor they will fit an early motor? That I can do...
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #8 of 11 Old 04-12-2015, 01:54 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Look into bar none diesel in Oregon. They make their own e99 bellowed up pipes and I'm running them. I think they are good quality and have had them for about two years now. No problems whatsoever
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #9 of 11 Old 04-19-2015, 05:13 PM
Quoted: 13 Post(s)
Yes. E99 turbo sits lower. Have fun mocking that up with an installed motor.
E99 CCLB DRW running as a SRW, 2006 Dana 60 coil sprung front axle swap w/6" lift on 37" Nittos. S366, Unlimited 238/100s, T500, 910s, studded, dual fuel pumps w/DIY regulated return, 6637, Hydra w/gearhead tunes. 2011 box + way too much other crap.
MNguy is offline
post #10 of 11 Old 04-20-2015, 05:20 PM
Doesn't Even Care
Quoted: 69 Post(s)
Yeah, you're not gonna mock that up with motor in cab... There's no way
Nick
"The Mistress"
