4r100 to zf6 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-14-2014, 07:25 PM Thread Starter
4r100 to zf6
alright i have a 4x4 7.3 4r100 and the trans is getting really hot like 220 driving for 30 mins iv thought about rebuilding it my self. but toddy i came across a truck on craigslist that had a zf 6 trans in it and it was cheep!!! only problem is that the would be donor truck is a 2 wheel drive. so my questions are what would i need to make the zf6 4 wheel drive? could i use my current transfer case? or should i just scrap the idea and just build up my 4r100?
thanks
stroking for life is offline
post #2 of 3 Old 02-14-2014, 11:54 PM
schlutzer's Avatar
Quoted: 18 Post(s)
The cost to convert a zf6 from 2wd to 4x4 would be very high. You need the output housing and shaft at least. And it's not a T5 where any idiot can put it together it needs a fair bit of specific knowledge.
The transfer case is easier you just need the input shaft swapped that you can do yourself.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 3 Old 02-15-2014, 04:44 AM Thread Starter
That's kinda what I figured. So were Is a good plAce to get a 4r100 rebuild kit. I kinda want to go with a little bit stronger one then stock. You can I check/test me torque converter?
