e99 turbo upgrade - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-28-2014, 05:16 PM Thread Starter
e99 turbo upgrade
Ok so taxes are coming soon and i'm going to have some money to finally upgrade my turbo and injectors. my question is what all am i going to need to upgrade the turbo on my e99. also i have read about putting a D66 on this truck but im not too sure that it would even bolt up. so i guess another qusttion is what turbo do i want/need to put on this truck? im only looking for about 450-500HP
stroking for life is offline
post #2 of 10 Old 01-28-2014, 06:30 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
A set of 238s or 250s with either a 100 or 200 nozzles will get you plenty of fuel. You would be good with either the d66 for the e99 from beans(get the billet wheel upgrade also) or go with the brute66 turbo from no limit for the e99(with the billet wheel) and you'll be very close. I.haven't dynoed my truck in a couple years, but since then, I've put bellowed up pipes, a larger fuel pump and diesel sites ww2 billet wheel, and im sure I am closer to the 430 mark with just my 160/80s....
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 10 Old 01-28-2014, 06:31 PM
Doesn't Even Care
Quoted: 69 Post(s)
And yes, the e99 versions of both of those bolt right up....
Nick
"The Mistress"
post #4 of 10 Old 01-29-2014, 08:00 AM Thread Starter
So is the d66 better then the gtp38r for this application? Why/why not? What are the differences between these turbos? What is price difference? Also what would I be able to push out of 160cc injectors with either of these turbos? I'm in the military so I'm on a bit of a budget.
post #5 of 10 Old 01-29-2014, 08:20 AM
Doesn't Even Care
Quoted: 69 Post(s)
the 38 R is gonna have to be a full conversion for your truck. it will not fit without the following....late 99 and up pedistal, up pipes(or bellowed pipes), Y pipe(or cfm+ type intake manifold) and the three inch intakes, PLUS the 38R turbo....
the 38R turbo is ball bearing, so you cannot just rebuild it say something goes wrong with it. you have to buy the center section at nearly 800 bux, versus a rebuild for the d66 or no limit tuning version they call a Brute 66 turbo.
Id go with the cheaper option, as I did with my truck. with the 160/100s your setup will look exactly like mine. and your numbers will be right on par with the numbers in my sig. You will be happy. be sure to get good tuning for your setup. I recomend PHP and their hydra chip or tony wildman(I have both their tunes on my truck and I love them both), but no limit tuning is good, as is matt from gear head.
Nick
"The Mistress"
post #6 of 10 Old 01-29-2014, 08:24 AM
Doesn't Even Care
Quoted: 69 Post(s)
price is gonna be very similar for each turbo, but its the setup and all the other stuff youre gonna have to do with the 38R thats gonna cost you. if you have the money to go with the 38R option, look in to going with a T4 setup. T4 setup allows you to run a huge selction of chargers and they are easily swapped out once you get the set up in.
if you look at the t4 route, Id look at Diesel innovations setup, with the s366 or the H2E charger....its gonna be alot more this way, but if you have the money, do it this way.....
Nick
"The Mistress"
post #7 of 10 Old 01-29-2014, 07:30 PM
Quoted: 818 Post(s)
Running 160/100's your never going to consistently see 40+ psi boost. Thats what wipes out a 38R. Keep you oil changed with good synthetic oil and it'll last a long long time. Of course thats if you want to go that route. A D66 is a good choice too.
I only went the 38R route because I initially got all the parts necessary for $150. So if your on a budget then get the D66. If not. Don't let the "non rebuildable" ney sayers deter you. I haven't heard of anyone wiping one out on here anyway.
Have you ever had feelings for a nun??? "Nacho Libre"
Corey@CNCFAB is offline
post #8 of 10 Old 04-11-2014, 04:42 PM
Different turbos
I have an e99 with new injectors, T500 HPOP am I reading the thread saying you can switch to a larger turbo without changing everything. Whats a D66 turbo. thanks
COP-OUT is offline
post #9 of 10 Old 04-12-2014, 05:24 PM
Doesn't Even Care
Quoted: 69 Post(s)
Look up at dyno proven.com, or beans diesel.com....it's called the brute 66...you'll have to have the one for the e99 trucks
Nick
"The Mistress"
The Following User Says Thank You to HVAC SuperTech For This Useful Post:
COP-OUT (04-15-2014)
post #10 of 10 Old 04-17-2014, 05:17 AM
Thuglike's Avatar
They are on sale now too!!!!
Thuglike is offline
