E99 to L99 Track Bar Conversion - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-03-2014, 03:49 PM Thread Starter
Quoted: 3 Post(s)
I've done a ton of searching and haven't found the exact information I need. I'll be installing a L99 adj track bar on my E99 f250. I understand that I need to drill out the bracket and axle bolt hole to accept the larger bolts but what bolts and nuts do I need to buy?
I've found the bolts and nuts on some online Ford suppliers but, the way I understand it, the L99 nuts are flanged with a small tab that keeps it from spinning and the E99 nuts are not. Therefore, the nuts won't work. Is this true?
These are the part numbers I have for the L99 track bar bolt and nut.
W706345-S439 -M20 Shoulder Bolt
N811886-S436 -M20x2.5 Flange Nut
Are these what you guys are using? Do they need to be bought from Ford or will Fastenal or somewhere else work?
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #2 of 8 Old 01-12-2014, 07:34 PM
Cummins_Killer's Avatar
I know maxx lift dot com sells a track bar bolt kit.
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-Diamond Eye 4" Turbo Back Straight Pipe
-33" Nitto Trail Grapplers on 18" XD Diesel
-2.8" Leveling Kit
Cummins_Killer is offline
post #3 of 8 Old 01-13-2014, 08:45 AM Thread Starter
Quoted: 3 Post(s)
It's funny you say that.... I finally came to terms with their ridiculous price of $40 for 2 bolts and 2 nuts when I received their shipping quote. They wanted $18 for UPS ground!
I was able to use their site for the OEM part numbers, purchased them for $20, and will cut off the flange tab on the nut to make it work
01 Ex 7.3l Limited
06 headlights
post #4 of 8 Old 01-13-2014, 08:56 AM
Yea i know their pricing is pretty rediculos, i decided im just gonna make my own track bar drop brcket for my leveling kit for my E99
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #5 of 8 Old 01-14-2014, 10:34 AM Thread Starter
Quoted: 3 Post(s)
You don't need a drop bracket for a leveling kit. This will take your drag link out of alignment with your track bar and cause bump steer
01 Ex 7.3l Limited
06 headlights
post #6 of 8 Old 01-14-2014, 10:41 AM
But if i put it on without one wont the axle be off centerd?
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #7 of 8 Old 01-14-2014, 10:44 AM Thread Starter
Quoted: 3 Post(s)
You need a longer track bar. This can be done by sleeving and lengthening the stock one or buying a longer adjustable one. Maxx-lift makes an adjustable one for the e99 but most people go with the newer model adjustable. I went with Trevors over at Precision Metal Fabrication. The bracket and frame mount will have to be drilled out with a 3/4" bit to fit the larger bolts but it's an easy mod and stronger than e99 stock
01 Ex 7.3l Limited
06 headlights
post #8 of 8 Old 02-03-2014, 08:15 PM
Colin7.3's Avatar
Prothane Front Track Bar Bushings 15 5mm Bolt Ford F250 4WD 1999 Super Duty 19 | eBay
will this bushing kit work in my e99? if i just drill the mounts out to accept the laarger bolts?
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
