Early 99 diy intake - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-17-2013, 07:04 PM Thread Starter
Cummins_Killer's Avatar
Early 99 diy intake
I just ordered my 6637 air filter, what else do i need to install it to my truck? Just a 4.5 inch hose clamp and a 45* 4 inch bend?
Cummins_Killer is offline
post #2 of 5 Old 02-04-2014, 02:32 PM
That should cover it. A pre filter cover to the 6637 is a nice addition. Helps extend the life of the filter and they look nice.
powersmok is offline
post #3 of 5 Old 02-04-2014, 10:53 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
yep, ladies nylons work as great pre-filters, use these in the sand
although you might need some biggggg nylons for the filter haha
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #4 of 5 Old 02-14-2014, 03:38 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I have gotten by with using straight 4" pipe (not the 45) on my E99. However, flipping the intake tube from the filter to CCV fitting end-for-end and rotating for best fit is needed, and the filter ends up on an angle, not square to fender and battery. Which actuly allows less blockage of the filter and better air flow because its not tight against the battery.
Edit: 4" pipe needs to be about 6-7" long.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #5 of 5 Old 09-16-2014, 07:16 PM
Quoted: 23 Post(s)
Came across this thread, and thought I'd add this picture of what I described above.
Greg
Semper Paratus
The Following User Says Thank You to dieselcrawler For This Useful Post:
JAC Wagon (02-13-2015)
