00 engine in a e99? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-13-2013, 01:50 PM Thread Starter
7.3L PowerStroke's Avatar
00 engine in a e99?
Will a engine out of a 2000 fit fine in my e99? Or is it totally different harnesses?
Thanks
-1995 F350 PSD (SOLD)
7.3L PowerStroke is offline
post #2 of 3 Old 12-13-2013, 07:08 PM
Quoted: 760 Post(s)
It will fit. Just use you e99 harness.
Edit: And just delete the AIH on the bigger spider
Corey@CNCFAB is offline
post #3 of 3 Old 12-16-2013, 10:50 AM
CSIPSD's Avatar
Ditto... You will need to swap the drivers side manifold or run all the 2000 motor stuff.
What are your plans? Complete long block swap or?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
