Early 99 power upgrades - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-22-2013, 08:46 AM Thread Starter
Cummins_Killer's Avatar
I have an a early 99 7.3 with 175k on it. im looking to get some more power out of it so I was thinking first I was going to get a TS chip, straight pipe, and diy intake. then a little while down the road get a 17* hpop and larger injectors. would these upgrades give me a noticeable difference? also will the ts chip work with the upgraded hpop and injectors?
Cummins_Killer is offline
post #2 of 4 Old 11-23-2013, 06:49 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
that would be a good setup.
you should be able to use your 15* hpop just fine as long as its healthy.
single shots use less oil than stock split shots.
then if you need a new turbo a d66 is a great drop in turbo that will support 450-500hp.
ts chips with custom tunes makes a huge difference.
dont forget gauges!
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #3 of 4 Old 01-27-2014, 04:21 PM
Would a stock hpop hold up to d66 turbo ?
And what other Mods do I need to do if I do swap to the d66
129rich is offline
post #4 of 4 Old 01-28-2014, 04:07 AM
You should start your own thread with your questions rather then resurrecting an old thread.
But to answer your questions no mods needed D66 and Brute 66 are the drop in options for E99. Your turbo has nothing to do with the health of your HPOP, the OP was asking if his stock 15 degree HPOP would keep up with larger single shot injectors.
cory99 is offline
