low mpg and and oil in the valley - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-29-2013, 08:46 AM Thread Starter
so i have a e99 psd im getting about 9mpg and looking to increase that. the truck has a tymer intake and and 4'' turbo back exhaust.
and as for the oil in the valley its all gathering right under the turbo pedestal and spider. its not comong from the HPOP or the turbo. its kinda all over the rear of the passenger head not too sure. and how much oil should i be seeing in the turbo pipes?
stroking for life is offline
post #2 of 4 Old 10-29-2013, 06:25 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
thats oil from the ccv, it vents into the intake.
completely normal.
you most likely need new intercooler and manifold boots. they are oil soaked and no longer any good.
you can do the ccv too if you dont want oil in their anymore.
riffraff sells a good boot kit
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 4 Old 10-29-2013, 07:34 PM Thread Starter
so that should clear the up the oil? and is there no way to flush the intercooler? and any input on the mpg problem?
post #4 of 4 Old 10-29-2013, 08:33 PM
Quoted: 258 Post(s)
that could be one of your leaks, i would clean up the motor and start and and check for leaks.
these trucks can leak oil a lot of different places on top of the engine.you can take the intercooler out and mix some water and dawn in their and that willclean it out.
