GPR Bypass Switch? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-09-2013, 08:15 PM Thread Starter
dylanj075's Avatar
GPR Bypass Switch?
A little background info. I have an early 99 7.3. I am currently in college in South Dakota where it does get cold. Problem is, I have no where to plug it in. No outside outlets on campus as far as I can see. I have heard of a glow plug relay bypass switch which supposedly makes the truck a whole lot easier to start in very cold temperatures. My question is, are these things worth it? And if so, how do I go about installing one? I have very little knowledge on this so any input would be nice.
dylanj075 is offline
post #2 of 13 Old 10-09-2013, 08:19 PM
timmyboy76's Avatar
never heard of it bud, but you could install synthetic oil..5w/40 and that will help with cold starts.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 13 Old 10-09-2013, 08:22 PM Thread Starter
dylanj075's Avatar
I haven't been able to get much info on them either. Google came up with nothing. It is possible the guy that told me about them is just an idiot. I'll dig a bit more and see
post #4 of 13 Old 10-09-2013, 08:35 PM
timmyboy76's Avatar
probably..only "mod" i know for the gpr, is with a led light, to let you know, when the gpr is on / off, to then fire truck up, since the WTS is a dummy light.
post #5 of 13 Old 10-10-2013, 01:09 PM
CSIPSD's Avatar
You could always bypass the GPR and just put the glow plugs on a switch or momentary button, but why?
You do understand the WTS light has NOTHING to do with how long the glow plugs are on right?
Turn your key on, and wait about 15 seconds, then crank...
This is assuming your glow plug system is working properly.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 13 Old 10-14-2013, 10:05 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
stancor glow plug relay is the way to go.
synthetic oil helps big time.
i go up to cold weather occasionally, 5-15 degress, and my truck starts no problem without being plugged in.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is online now
post #7 of 13 Old 10-14-2013, 10:23 PM
Rodslinger's B1TCH
one more for synthetic oil. I've been using rotella t6 and it's been starting great. it's not a glowplug issue, the injectors glue themselves together with cold, thick oil. thinner oil that isn't affected by temperature will allow the injectors solenoids to move the armatures.
I have a glow plug bypass switch on my truck to turn the glow plugs off in the summer to reduce wear and tear on them. under normal circumatances the glow plugs just work they way they should until the engine reaches a certain temperature.
steve604 is offline
post #8 of 13 Old 10-24-2013, 12:15 PM Thread Starter
dylanj075's Avatar
Yeah I'll give synthetic a try. It hasn't gotten too cold yet so I haven't had any major problems, but it will. Thanks for the help
post #9 of 13 Old 10-24-2013, 01:25 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Living in SD chances are your not gonna see temperatures that your truck cant start in. If you have a good functioning GP system your not gonna have any problems starting in ~0° temps unplugged. The truck will surely hate you and p--- smoke everywhere but it should start.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #10 of 13 Old 12-07-2013, 08:35 PM Thread Starter
dylanj075's Avatar
Thanks for the input. It has been cold here the past few days, about -10 for the past 3. This past Wednesday, I went to start it to go to work. It was a hard ***** to start but it fired up, but I must have cracked something because now I have a diesel leak. I probably broke a line or something. Not a huge deal, I just need it to warm up enough to go out and try to diagnose and fix the problem
