Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
  #11 (permalink)
Old 04-12-2008, 10:00 AM
Diesel Nick Diesel Nick is offline
I have excessive flatulance!!
Tournaments Won: 1
Send a message via AIM to Diesel Nick
Well with the mods in my sig I can get a max boost of 25psi I know its now a 99 but maybe that can help you... Also did you unplug your wastegate?
  #12 (permalink)
Old 04-12-2008, 10:42 AM
01_stroked_7.3 01_stroked_7.3 is offline
Send a message via AIM to 01_stroked_7.3
yeah, it seems a lil low. Like you said you have an early 99, so i don't know what is normal, but just thought i would through what i get out there. I have an 01 with ts chip and i get 28 on the 100 hp setting.
  #13 (permalink)
Old 04-12-2008, 04:18 PM
cvdenson cvdenson is offline
The max I've been able to see with mods in my sig is 23psi.
Chris
  #14 (permalink)
Old 04-12-2008, 04:30 PM
CoalRollinRoosterCruiser CoalRollinRoosterCruiser is offline
Mighty Mouse
Send a message via AIM to CoalRollinRoosterCruiser
well, i was mistaken. I checked for you while i was out earlier.
Mine is a 2000 , but on the 100hp setting i get bout 22 psi WOT.
  #15 (permalink)
Old 04-13-2008, 06:59 AM
binder man binder man is offline
wow i can hit 30 and it's goin strong till I hit my speed limiter
  #16 (permalink)
Old 04-14-2008, 07:00 AM
alabamafrog alabamafrog is offline
Powerstroke Techie
My early 99 with the stock turbo and stock injectors and a TS chip set at 140 would hit 28-30 psi easy. You may be running out of high pressure oil instead of running out of fuel. I did have my waste gate rod tightened up a little and the hose disconnected. My egt would easily get to 1300 degrees. If you can get a scanner or predator programmer you can watch the ICP and other stuff to see why the 140 setting isn’t working for you. Also may want to hook a gauge with a long hose to the head and watch fuel pressure at WOT.
  #17 (permalink)
Old 04-16-2008, 08:24 AM
losfinch losfinch is offline
Last week I was hitting 44 pounds after I unhooked the wastegate! Running stock, too. I thought something was gonna blow...until I realized that I had accidentally set my Recon ZXT gauge for a Dodge instead of a Ford...
Now I'm back to 15ish again.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
