E99 turbo conversion - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-07-2013, 06:04 PM Thread Starter
The start, I converted my e99 to new style turbo. I installed bellowed up pipes, I used the .84 exhaust from e99 and the 1.0 compressor from a 2003 van, the old turbo had a ww and now I use the compressor from the 2003 van. Of course I had to install a taller pedestal, I'm still using the stock exhaust, and removed the ebp gate, I have super chips tuner, and napa 6637 air filter.
As e99 setup with tuner, exhaust temps would hit 1200 wot & 20 psi, and at 70 mph I would have 3 psi and 300-500 exhaust temps. Idol is 300 degrees,
New set up with tuner, wot is never over 1000 degrees & 25 psi, 70 mph is 600-800 and 5psi, idol is 400 degrees,
Now the question, I thought that temps would be lower? Are the higher temps ok? Should I have changed something else? I will be doing 4" exhaust next, but I don't want to hurt my motor running higher temps. My goal for this project is better mpg, not power. Any suggestions would be appreciated.
Saster25 is offline
post #2 of 5 Old 07-12-2013, 05:00 PM
Quoted: 39 Post(s)
Still got the e99 turbo?
2008 f250 king ranch ccsb: under construction
blacksmoke powerstroke is offline
post #3 of 5 Old 07-12-2013, 05:26 PM
superstack's Avatar
Ww is stock on e99... just sayin but did you put it in the newer housing?
superstack is offline
post #4 of 5 Old 07-14-2013, 01:20 PM
Quoted: 39 Post(s)
So still got the turbo
post #5 of 5 Old 07-17-2013, 06:39 PM
Quoted: 780 Post(s)
All your numbers are pretty normal especially since you still have stock exhaust. Straight pipe that thing.
Corey@CNCFAB is online now
