no start no wts light - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-24-2013, 11:42 AM Thread Starter
Some background, bought an early 99 in used 2010 for occasionaly use. It sits most of the time. It started acting wierd & would die occasionally but would always start back up, does it more when raining & ses light comes on. Once i noticed the wait to start light did not come on, & it did not start. A few more key turns & it comes on & starts. Looking around i noticed the bottom screw on the pcm that goes thru the firewall is gone & I assumed the prior owner had a chip on it & removed the chip/tuner & was too lazy to replace it. Some time went by & i recieved a recall notice from ford on cam pos sensor & speed control. When I took it in, i mentioned the missing screw. When I left the dealer they said they put the screw in & all was well. Drive home in the rain with zero issues & think ok this mess is fixed. Next time i go to start the truck service engine soon comes on with the key turn & the wait to start light never comes on. My first guess on this is to remove & try to clean the pcm contacts? What should I clean it with or what else should i check out? This is an extra vehicle so i can take some time. i had to drive my car on the donut today because the truck won't start. I need to learn more about this thing. Thanks
Tractorsaw1 is offline
post #2 of 9 Old 06-24-2013, 12:25 PM
ADMIN AND TECH
SCUFFY828's Avatar
your fuel heater is shorted , unplug the fuel heater ,white connector on back of filter housing and replaced blown fuse , it will start then
ITS STOCK
SCUFFY828 is offline
post #3 of 9 Old 06-24-2013, 12:46 PM Thread Starter
Thanks scuffy, I assume I will need to replace the fuel heater before it gets cold as the long term fix? Sorry for being a big dummy on these, but where is this fuse located & what amp size is it? I assume it is a blade type? Thanks again for the fast fix!
post #4 of 9 Old 06-24-2013, 03:15 PM
ADMIN AND TECH
SCUFFY828's Avatar
I think its fuse 22. Its a 20amp
ITS STOCK
post #5 of 9 Old 06-25-2013, 04:02 AM Thread Starter
I checked the fuses under the hood. 1 blown 7.5 fuse. Looking from the front of the truck it is the second 7.5 from the front on the left. Everything else looked good. There was a metal fat one I couldn't tell if it was bad or not. I will pick up some fuses tonight & see what happens.
post #6 of 9 Old 06-26-2013, 09:57 AM Thread Starter
I couldn't find any bad fuses under the dash. Service engine soon light is on & the wait to start light does NOT come on. Anyone know what powers the pcm, it has to be that.
post #7 of 9 Old 06-26-2013, 11:13 AM
ADMIN AND TECH
SCUFFY828's Avatar
you are thinking correct , no power to pcm means no wait to start light, fuse 30 in the dash is a 30 amp , check that one, also if you can get to the ipr wiring check the red wire in that connector and tell me if you have 12 volts there
ITS STOCK
post #8 of 9 Old 06-26-2013, 11:24 AM Thread Starter
After doing some more reading in the motor problem section another member had a snow plow wired in to the pcm fuse. I belive I have a radio wire or something that someone smashed in with one of the fuses under the dash. I am going to remove that & see what happens. What is the IPR? There are so many abbreviations on this site I guess i missed where to lookem up at. Thanks Scuffy!
post #9 of 9 Old 06-28-2013, 03:36 AM Thread Starter
The plastic cover that holds the pcm did not have the top screw in & the bottom was loose. It was tough to get the top screw in. Got it in & tightened both of them up, wait to start came on & fired up. Thanks for the help
