Transmission question?. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-31-2013, 02:05 PM Thread Starter
Hello, I would like to know on my Early99 F350 7.3L with the automatic transmission, does transmission fluid flow through the transmission oil cooler constantly? Or does the fluid only go to the cooler at a certain temperature? I have a transmission temperature gauge and I am in the process of adding a transmission fluid cooler. I was driving today the transmission temperature was at about 180*, I felt the transmission lines running to the radiator and neither of them was warm. I am wondering if I don't have any fluid flowing through the cooler or if it is normal until the transmission reaches a specific temperature.
Thanks to all who reply.
Sent from AutoGuide.com App
Fritzimax is offline
post #2 of 4 Old 07-07-2013, 06:16 AM
natureboynate47's Avatar
The 4R100 does have a cooler bypass. Can't find the temp specs for it though.
Early 99 F-350 crew cab short bed auto trans
FBD 5" exhaust, AIS filter, 160cc Single shots, T-500 HPP, Gen2 WW, ITP regulated return, DP tuner, 6.0 IC and trans cooler, JW valve body
natureboynate47 is offline
post #3 of 4 Old 07-17-2013, 06:46 PM
Quoted: 898 Post(s)
Feedback Score: 3 reviews
Yep, flows all the time.
Corey@CNCFAB is online now
post #4 of 4 Old 07-18-2013, 07:31 AM
Quoted: 6 Post(s)
If I remember correctly, Mark K said that the bypass is simply to prevent the tranny from not getting fluid if the cooler gets blocked. It doesn't aid in warmups/cool down of the fluid/transmission.
I could be wrong, but you may want to search under his name. You'll find plenty of good info about the transmission.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
