Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
Old 03-09-2008, 05:35 PM
electrod electrod is offline
Question 6.0 INTERCOOLER
Can anybody tell me what is involved to swap in a 6.0 intercooler other than take out the old and in withthe new? THANKX IN ADVANCE
Old 03-09-2008, 10:57 PM
blk99 blk99 is offline
open hood, take off plastic cover between grille and radiator support, take hood latch loose and move it out of way, unbolt the A/C condesor hold downs from the rad. support, take the jack handle holder thing off which is also the brackets that hold the top of the radiator (the rad. will just lean back), take the bolts out of each side of the rad. core support (2 or 3 on each side and both front and back.... 8 or 12 total), unbolts the intercooler from the rear side of the support, be creative and wiggle the rad./core support out, loosen the clamps on the I/C boots and take them off, and now you can work the I/C out.... some people have taken the Degas bottle loose but that didnt help me.... I just moved the A/C condensor lines around until the I/C came out.... just need to be creative....
just lower the 6.0 in there and repeat in reverse!
hope that helps
~Jim
Old 03-10-2008, 02:27 AM
99 7.3 99 7.3 is offline
don't forget that you'll need diff. 6.0 ic boots. the 6.0 ic boots will not fit on your boost tubes. the ic inlet and outlet are diff. size than the 7.3 ic. make sure you measure before you buy. the 6.0 ic's came in diff. sizes. i'm pretty sure that you can get them from dieselsite.com..
Old 03-10-2008, 05:00 AM
Mikes7.3 Mikes7.3 is offline
General Tech, Maintenance, and Mod info
Gcop has a good write up 6.0/7.3 I/C swap in this forum
Old 03-10-2008, 05:23 AM
bigwhite7.3stroker bigwhite7.3stroker is offline
Dirty South Stroker
This is a great upgrade I did it a few months back and made pretty good improvement with the EGT's.
Old 03-10-2008, 04:15 PM
THANKX AGAIN GUYS FOR ALL THE INFO.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
