Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
Old 02-10-2008, 09:25 AM
eaton34 eaton34 is offline
Fuel pressure gague...where?
I need to hook up a pressure gague and was wondering where i would install this on an early 99 fuel bowl? thanks
Old 02-10-2008, 09:28 AM
todd todd is offline
my tranny hates me
theres a #4 or 5 orb on the back side of the bowl toward the bottom goes there
Old 02-10-2008, 09:29 AM
SCUFFY828 SCUFFY828 is offline
SUPERDUTY GURU
pressure should be 55-60 lbs
Old 02-10-2008, 12:08 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
I removed a plug in the front top corner of the passenger side head and put a 45 degree JIC fitting in it and ran a hose over to the engine hoisting bracket and attached a sending unit to it. The fitting is kinda hard to get to between the fuel bowl and head. The one mentioned above might be easier or better to use, I just wanted to know the actual pressure at the head.
Here is a pic of the back of the fuel bowl on my early 99
Old 02-25-2008, 07:42 PM
strokermann strokermann is offline
ok looking at that pic were does the fitting go cause i am wanting to put a fuel pressure gauge in as well. thanks
Old 02-26-2008, 08:35 AM
losfinch losfinch is offline
Scroll down to the last page in this writeup to see where to pipe in the fuel gauge on the back of the fuel bowl.
http://www.dieselinnovations.com/tec...structions.pdf
Old 02-26-2008, 08:39 AM
thanks. so much.
Old 02-26-2008, 03:51 PM
strokin_early_99 strokin_early_99 is offline
Fat Truck Racer
The fitting on the bowl is a #4 O ring boss. Nice pic Froggie.
Old 02-29-2008, 04:50 PM
Could that same hole be used as a return in a flow through fuel system? I'm trying to think of how to do a flow through set up (from the rear of the heads to the front) using the factory fuel bowl and regulator.
Old 02-29-2008, 07:03 PM
Fat Truck Racer
If you run lines from the bowl to the heads it will only be putting fuel into both ends of the heads. The fuel bowl does not have a compartment that the return system flows into. The fuel bowl is pressurized and the extra pressure is bled off. So if you just put a set of lines into the bowl it will feed all the ports with fuel and will still return the fuel from the bowl to the tank.
If you want a flow through system, you need a regulated return system like the one available from ITP Diesel.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
