lift question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-10-2013, 06:41 PM Thread Starter
96MegaStroker's Avatar
Send a message via MSN to 96MegaStroker
Question lift question
So im looking to lift my early 99 250 8" but i been lookin around at lifts and i see some people say early 99 and late 99. Whats the difference with the suspension?
07.5 MegaCab 3500 10 1/2" lift on 38s
1985 Ranger 5.0 swaped
2003 Mustang with a kenne bell
96 F250 sold
99 f250 sold
96MegaStroker is offline
post #2 of 2 Old 04-10-2013, 07:17 PM
Macon's Avatar
*Edit* I guess I can't link to there.
Parts you care about:
The E-99 front axle U bolts are square where they go over the spring pack. The later 99 U bolts are round.
The E-99 track rod has smaller mounting bolts than the later 99-03.
The E-99 has a different pitman arm than the later 99-03.
Complete list copied:
Early 99 has a wicked wheel in it from the factory.
The E-99 has 130cc(AB code) injectors and the later 99-03 has 140cc(AD code) injectors.
The E-99 has 2" intake runners. The later 99-03 has 3" intake runners.
The E-99 has a 15* swash plate HPOP. The later 99-03 has a 17* swash plate HPOP.
The E-99 has one glow plug relay. The later 99-03 has one glow plug relay and one air intake heater relay side by side. Both relays are on the passenger side valve cover toward the front of the truck.
The E-99 has a totally different air filter that is not inter changeable with the later 99-03. But you can put the late 99 air cleaner assembly in the E-99 truck.
The E-99 has shallower rotors than the later 99-03.
The E-99 has shorter hub-bearings than the later 99-03.
The E-99 does not have the AIH like the later 99-03.
The E-99 does not have the automatic transmission fluid cooler in the radiator.
The E-99 has no indicator light showing that "cruise" is on. Later 99-03 has a cruise light that will come on when you set the cruise control. Some of the E-99 trucks have this light in the dash already. A newer PCM(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green light on the right side edge, half way up.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
