Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
Old 01-29-2008, 12:53 PM
stagbeer stagbeer is offline
After FPR mod have you noticed hard starting?
Initial startup after mod was normal but now after driving 8 or so miles to town, turn iginition off, wait 20 minutes...the restart cranking time seems to take twice as long. It has done this the last two trips, air temp 50 to 60*.
It starts normal on a cold start in morning but not after warm up? Same fuel, nothing different but the BB.
Old 01-29-2008, 01:07 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
Never heard of the FPR shim causing hard start, had mine done for about 6 months now with no problems. I seem to remember folks talking about the IPR o-rings causing a hard start when hot condition.
Old 01-29-2008, 01:18 PM
strokin_early_99 strokin_early_99 is offline
Fat Truck Racer
It does not make sense that it could make it start different. The fuel pump is electric and the turns on when the key is turned on.
Mine was on for 4-5-6 years, heck if I can't remember. No problems ever. It use to run at 72psi and after all the years it ran 68psi. Never had a problem.
Old 01-29-2008, 04:05 PM
OK...I did not check the new fuel pressure, just done the BB mod & run. Can the increased pressure have ill effects to the old fuel system in such a manner?
I don't know if the excessive cranking is due to too much fuel or not enough. No smoke at all in exhaust & fuel pump "sounds" as normal with key in the on position.
Could there be too much pressure existing after engine shut down to hinder warm start up?
Old 01-30-2008, 06:09 AM
Powerstroke Techie
not likely
Old 01-30-2008, 06:41 AM
cebulmer1 cebulmer1 is offline
With higher fuel pressure it will not effect the fuel system, how ever too much pressure will push out the rubber o-ring in the fuel bowl.lol. dont ask me how I know.
Old 01-30-2008, 10:06 AM
Quickhorse Quickhorse is offline
I was thinking of doing the bb thing on my 99 (10/98) stroker. Is that all you do . . . take the FPR apart and put the bb in the end of the spring and then put it back together and startup?
Old 01-30-2008, 10:14 AM
I haven't noticed any leaks and the bowl gasket is normal. Suppose I'll take that BB out and see if it will correct.
By the way, I never felt any performance gain with the FPR mod as other folks say they did.
Old 01-30-2008, 10:23 AM
Pretty much, but..
Do a search for the FPR mod, it will have pics and directions. Early 99s are different (have to remove two torx head bolts) to access spring.
I would have a 5/16" fuel line sleeve handy too as mine tore apart during dis-assembly.
Old 01-30-2008, 11:00 AM
Fat Truck Racer
FYI, the early99 is the same as 99-03 7.3. Nothing special on the superduty when it comes to the early birds. However it is different than the OBS, 94-97.
Look here for the pics of the mod and where the BB goes: FPR Mod pictures from friends & fun photos on webshots
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
