front axle - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-30-2013, 01:40 AM Thread Starter
front axle
I'm trying to change the ball joints and can't get the axle out. build date is 5/98. I watched the video from the tech files and it just isn't coming out. Everything has been super easy. had it all tore apart in 30 mins. Does the axle slide straight out of the knuckle like in the video? or am i missing something? I even used a 4lb hammer, but don't want to damage the u-joints. Can't afford to have this done. help please.
early 99 250 Lariat s/c s/b 4x4
DIY intake
4" MBRP turbo back straight w/ 5" tip
3 piller gauges- boost, pyro,trans
TW tuned -
stock, h/idle, econ, L-tow, H-tow, extreme
t/c lock switch
HPX line
regulated fuel return
warn hubs
cbremodel is offline
post #2 of 3 Old 03-30-2013, 01:57 AM
JSchuricht's Avatar
Once everything is apart, the axle just slides out. There are a few seals that may give you a bit of resistance. You should post some pics and we might spot the issue.
JSchuricht is offline
post #3 of 3 Old 03-30-2013, 03:00 AM Thread Starter
Thanks, getting ready to try again.
DIY intake
TW tuned -
t/c lock switch
HPX line
warn hubs
