E99 Hub/Brake replacement $$$ - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-26-2013, 04:48 PM Thread Starter
khl
Just priced out new hub/brakes for a 1999 F350 (build date of 7/98) with dual rear wheels. $1086.82!!!
Motorcraft loaded calipers w/ superduty pads $83.79 x2
BRCLS77RM
BRCLS76RM
Raybestos rotors 13" $73.79 x2
66746
Timken hub assembly $324.79 x2
HA590425
+$70.32 shipping
-$100.00 for core on caliper return
End price $986.82
Really high in price than what im used to, hub assemblies specifically. I still have to confirm if 13" rotor because if I have 14" rotor thats more money. I have the option to use Pro instead of Timken which would save $200 each side but I hate using non brand name stuff especially on bearings!
Input?
khl is offline
post #2 of 10 Old 03-27-2013, 04:40 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Convert to late model unit berrings and rotors. Save $. Just buy unit berrings and rotors for the same spec trk only change model yr to 2000. I've done this to mine. The parts interchange fine. But you HAVE to do both the unit bering and rotor as a pair. If not the rotor hits the caliper bracket.
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #3 of 10 Old 03-27-2013, 06:27 AM Thread Starter
khl
So buy parts for a 2000 f350 7.3 4x4 which will be loaded front calipers, front rotors, and hub assembly units? Nothing else? And I'm assuming the rotors are going to be 14" now? Anything else to do the swap? Any links or a how to to convert or is it just a straight part swap. I will price out a 2000 list to see difference. I'd love to get a 14" rotor in there for extra stopping power
khl is offline
post #4 of 10 Old 03-27-2013, 11:48 AM
jshalala's Avatar
I am pretty sure you can use the same calipers, no need to change them to a later year. Just buy 2000 hub assembles and rotors and you will be good.
2003 Ford F250 6.0 powerstroke 4x4.
ZF6 manual trans, ext cab short bed
deleted, 4 inch exhaust, gauges, traction bars
16x10 Weld wheels wrapped in 33s
Early 1999 Ford F250 7.3 Powerstroke 4x4
Crew cab short bed
straight pipe, intake
jshalala is offline
post #5 of 10 Old 03-27-2013, 02:51 PM Thread Starter
khl
Yes but what rotor? The 14.53" or the 13.03" ??? Im seeing 2 on option to buy.
I am replacing the calipers because it needs new pads and the calipers dont look to healthy and I dont want to run the risk of getting it all apart and having the piston not press back in. Just buying loaded calipers for $80 each I can be done no cleaning or anything with hardware, etc. Saves me time to bolt in a loaded unit and bleed.
Here is the revised list. Mush cheaper on the hubs!!!
BRCLS77RM
BRCLS76RM
Centric rotors 13" $73.79 x2
12565086
Timken hub assembly $186.79 x2
HA590425
+$103.16 shipping
End Price: $757.46
Saved $230. This is still high but much better!!
khl is offline
post #6 of 10 Old 03-27-2013, 03:06 PM
jshalala's Avatar
I am trying to find a thread that I read today saying you should go with the 14 inch rotors when upgrading. I just read it earlier today, may have not been on this forum. Ill see if I can find if unless someone else can chime in.
Crew cab short bed
jshalala is offline
post #7 of 10 Old 03-27-2013, 04:35 PM Thread Starter
khl
Im assuming all i need is the rim clearance for caliper to be out an extra inch (which I dont see being a problem) and the caliper bracket on the loaded calipers I buy needs to be longer to accept the 14" rotor so in actuality, whatever loaded caliper I buy, I need to make sure its either for 13 or 14" rotor.
I need to order these parts ASAP and just want the right stuff here so I can go in there and get it apart and install and not have to run down to local parts store on a weekend they are closed and be stuck until monday. I do all my mechanic stuff on the weekends and order all my stuff from Rock auto. Obviously some stuff is unforseen and Im stuck doing stuff on monday when parts need to be ordered (stuff autozone, advanced, etc doesnt have in stock) but I try to order everything I need to complete jobs and have gotten decent at doing stuff as planned.
khl is offline
post #8 of 10 Old 03-27-2013, 05:00 PM
jshalala's Avatar
I found this thread
Early 99 hub changeout - Ford Truck Enthusiasts Forums
And Ive checked other forums and I am seeing that even the later trucks use the 13 inch rotor also
Crew cab short bed
jshalala is offline
post #9 of 10 Old 03-27-2013, 06:05 PM Thread Starter
khl
In that link, someone says the 14" rotors are used in f450s. Just to be sure, I'm going to pull the wheel and check to confirm.
So it looks like
E99 loaded calipers
00 rotors
00 hubs
Anything else I should order/replace as preventive maintenance?
For loaded calipers, I was just going to go motorcraft w/ superduty pads that come in them. Also was going to try the centric rotors but motorcraft and acdelco make a devent set too... Reviews? Not big into drilled or slotted. I don't mind using the feature but I'm not paying for it as I think it's all bogus anyways for what I'm doing with them
khl is offline
post #10 of 10 Old 10-01-2013, 03:14 PM
Send a message via AIM to Lifted94XLT
Is there anyway to tell by looking at the hubs if you have the 99 or 2000 hubs? I'm rebuilding the front end if my e99 and I just put the rotor on (bought for an e99) and the caliper bracket is hitting the rotor. Thanks for any help. If its not a different hub, I'm gonna have to figure out why it's hitting. Thanks
--Ryan
E99 F-350 Reg Cab w/ Flat Bed, 6spd 4wd
4" Turbo Back Exhaust, 05 Front End Conversion, 05 Outlaw Edition Door Panels and Seats... Intake, Straight-Pipe, and Chip Coming Soon
GONE:: 2004 F-250 CC SB Lariat FX4
AFE Stage II XP Intake; MBRP 4" Turbo Back (Straight-Piped) w/ 5" tip; SCT Tuned by DJ; Autometer Ultra-Lite Pyro, Boost, and Tranny Temp Guages; 4" Rancho Lift; 315/75x16 Big O Bigfoot XTs on 16x10 Eagle Alloys
Build Date:: 06/04
Lifted94XLT is offline
