Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
Old 01-23-2008, 02:22 PM
Dirk Dirk is offline
On vacation.
HPOP-Would this be a ball bearing 15 degree pump? Pic inside!
I finally got the cover off. A bit off MAPP gas to warm up the shell and the cover slips off. I was told it came off a 2000 7.3 but I'm not sure at this point. Click for larger view.
Thanks!
Old 01-23-2008, 04:16 PM
On vacation.
Bump. Anyone?
Old 01-23-2008, 06:46 PM
On vacation.
Bump for the night. Someone must know.
Old 01-24-2008, 05:23 AM
Evil Eye Evil Eye is offline
Slacker
again. I have no idea, bro.
Old 01-24-2008, 07:23 AM
On vacation.
After hours of digging around on the internet.. This is a 17* pump. I was confused because of the plate. If you hold a light next to the hole and spin the pump, it looks like a ball bearing on the inside. A 15* degree pump will have the ball bearing exposed. No plate at all on the back.
Old 01-24-2008, 07:54 AM
forddieseltweek forddieseltweek is offline
Post a pic of the back cover....
Old 01-24-2008, 07:57 AM
On vacation.
Back cover doesn't make a difference. It could be raised or flat. Once you remove the back cover, if you see what is in the pic above, it's a 17*. I called Bob at dieselsite to confirm.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
