Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
Old 01-21-2008, 07:30 PM
fordfan99350 fordfan99350 is offline
Send a message via AIM to fordfan99350
swamp vs dynomite
i talked to swamp on friday... with everything we talked about,was looking like 175/173's i asked what i should see to the ground. he said no truck will be the same... but 50hp or better depending on the HPOP and stuff.
then dynomite diesel called me back today,and i talked to them.
same talk and stuff... he said go with the stage 2's. i aske what i should see to the ground and was told 100-120hp closer to the 100 with my HPOP*.
*both will be with a TS chip,and i'll be putting in a new 17*HPOP when i install the injectors
who is running these and what are you seeing in hp?
what is the better one to go with.
anyhelp would be great, i would love to order them tomm. if i can make up my mind.
Old 01-21-2008, 07:36 PM
sikktruk01 sikktruk01 is offline
a friend of mine suggested Ryan Casserly @ full force diesel. might wanna talk to him also. I'm the same way especially about that kind of money. the more you know the better your equipped to make a good decision
Old 01-21-2008, 07:47 PM
Performance Oil Products Performance Oil Products is offline
The extrude honing on the Dynomites really does make that much of a difference. Were you talking about the stage 2 with 070 nozzles. They are good for around 90-100 on stock pump. I have a stealth and they should be good for around 120, but with proper tuning. My tuning comes from Jody at DP.
I know you can get the swamps for around 1600 or soand the dynomites run about 2100, but they are all 100% new and the less expensive swamps are rebuilt units.
Just a bit of info, hope it helps in some way
Old 01-21-2008, 07:58 PM
i was going to use jody, i called him today. i feal like i'm being a pain in the a$$ about this... i know all my buddys are sick of it. i'm not sure the size, i'm waiting on an e-mail from them with a quote with shipping. all i know was a single shot stage 2.
Old 01-21-2008, 08:00 PM
oh and I want to be able to smoke!!! able to, but not at every stop sign
Old 01-21-2008, 08:05 PM
Chrisf97305 Chrisf97305 is offline
Send a message via Yahoo to Chrisf97305
i put a set of Dynomites stage 2 in my 97, did befor and after dyno and got 93 hp on stock fuel and stock hpop. the truck really drives better with the stage 2 injectors then it did with stock injectors with the edge progromer.
Old 01-21-2008, 10:30 PM
strokin_early_99 strokin_early_99 is offline
Fat Truck Racer
I went with DDP for three reasons.
1) They EH the injector nozzles and flow match them to within 1lpm.
2) They have a 3year / unlimited mileage warranty.
3) They support the events in northern Ca that I attend. So I will support them.
Old 01-22-2008, 03:22 AM
i spent some time lastnight reading up on some old posts and i made up my mind. DDP it is. a few more $ than the swamp... but alot less then where i started!!
thanks everyone, i'll be hitting you all up for help when something goes wrong with the install! j/k
Old 01-22-2008, 03:44 AM
Don't say that man. There are plenty of how install injectors threads around so read as many as you can find, and keep the best copy handy.
You made the right choice and will be happy.
Old 01-22-2008, 04:45 AM
alabamafrog alabamafrog is offline
Powerstroke Techie
The guys at Swamps told me I should be putting down 380rhp with my setup. I haven’t had a chance to dyno it yet but that sure “feels” about right. I’m not overly impressed with Swamps tuning they did to my TS chip but she does burn the big mudders and bark second pretty good with a stock tranny. I hate when they call injectors stage II or stage III, I like it when they just tell you how much they flow. If I ain’t mistaken the only differences in injectors is how much they flow and if they are single shot or split shot.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
