steering issues - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-20-2013, 08:58 PM Thread Starter
preachermanhull's Avatar
Quoted: 2 Post(s)
steering issues
not sure if this should be here or under drivetrain but here goes...just bought a 99 7.3 sd and the steering is stiff on the road. Its a little tight while sitting but always enough to turn the wheel without much strain... i can live with that. Main issue is while moving at normal speeds. The steering seems like its stiff and has tight spots in it to me. Almost as if the power steering stops assisting once the truck starts to roll?? Engine rpms make no difference...in neutral at idle is the same as in o.d at 1500 rpm or drive at 2100 rpm. I have a 95 compareable truck and have never had this issue. My 99 has 265 75 16 tires so i don't think thats it. I tried loosening the steering box adjustment nut (thinking someone had gotten it to tight trying to remove play...worked on another vehicle before) with no change. Changed out the powersteering fluid (synthetic atf)..no change. My truck has had one side ball joints replaced so i greased them and tie rods..no change. So what should i try/check next?? I'm thinking the other two ball joints first. By the way...the hydoboost brakes work great so i'm thinking the pump should be o.k. Anyway, i realize the net is full of steering issue threads but they all seem to deal with hard steering at a stop...like i said, mine doesn't have much issue there. Any ideas...thanks!
Psalm 34:6 "This poor man cried, and the Lord heard him, and saved him out of all his trouble."
94.5 psd, 310,000,
ts chip, homemade cai,
3in dp 5in exhaust, 265/75/16 tires,
glowshift gauges,
zf5, fpr shim, bench seat so my honey can get close! SOLD!
98.5 psd, 245,000, new a/t, banks gauges, 06 interior, 4 inch exhaust 5 inch tip, the truck is red
-Hosstyle Dieselz-
2004 F-250 6.0 4wd, auto...and get this, 356,000miles on og engine/trans! Stock for now...
preachermanhull is offline
post #2 of 4 Old 03-21-2013, 12:28 PM Thread Starter
Quoted: 2 Post(s)
never mind...the two original ball joints were stiff. I got lucky, they weren't wore to bad yet...just dry. Drilled and tapped the lower for grease fitting, used pb blaster and then a needle greaser on the upper...problem solved! Drives like a Cadillac now.
94.5 psd, 310,000,
glowshift gauges,
-Hosstyle Dieselz-
post #3 of 4 Old 03-21-2013, 06:09 PM
timmyboy76's Avatar
thanks for the update. i just experienced the same symptom yesterday, driving in the parking lot...well that didnt sound right..
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 4 Old 03-21-2013, 07:25 PM Thread Starter
Quoted: 2 Post(s)
well...i'm not suggesting someone drill their ball joints but in my case i new they weren't wore...just dry and stiff. PB blaster and grease freed them right up! I know its not the right way to do it but it is alot cheaper. Besides, i check stuff like ball joints when i change oil then service them accordingly so if there is an issue with the drilled joint i feel like i'd catch it. I'm the King of fix it cheap when possible and feasible..lol!
94.5 psd, 310,000,
glowshift gauges,
-Hosstyle Dieselz-
