Oil change - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-13-2013, 04:35 PM Thread Starter
Oil change
I have E-450 Superduty 7.3 My son inlaw thought he would do me a favor and change the oil for me. Well he did, but in process he mixed my 5 qt jugs up and I ended up with 2 qts of Hotshots additive, 7qts of 15/40 diesel oil and 5qts of 15/40 semi-synthetic oil for my wife's Fusion. How bad will this screw things up, if at all. Should I drain everything and eat the cost. Interested in some
knowledgeable answers.
Thanks
rodgy2 is offline
post #2 of 7 Old 03-15-2013, 01:37 AM
timmyboy76's Avatar
i'd sleep better, knowing i put the right oil back in there respective vehicles.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 7 Old 03-15-2013, 02:31 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
15w-40 for a fusion?!?
im guessing the oil for the fusion is not cj-4 rating.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #4 of 7 Old 03-15-2013, 06:35 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
For fusion? Simple, drain it and just refill don't need to change the filter again... But a bigger issue is the 15-40 in your fusion, I'd put back a 5-30ish in.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 7 Old 03-15-2013, 07:51 AM
Macon's Avatar
0-20 for the Mrs. Camry...
Or did he dump all of that into the 7.3? If it's all in your F450, I wouldn't worry. I don't like mixing oils, but if they're all meeting the same SAE certs, then no biggy.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #6 of 7 Old 03-15-2013, 08:26 AM
PowerStrokeBren's Avatar
Yeah get that 15-40 out of that fusion asap! put 5w-20 in it.
2000 F-350 7.3L Powerstroke
Autometer gauges
Banks 6 gun tuner
Banks Wastegate Actuator
ATS Turbo Housing with WW
K&N CAI
Magnaflow 4" turboback
2 1/2 Leveling kit
35" MT ATZ
PowerStrokeBren is offline
post #7 of 7 Old 03-16-2013, 09:41 PM
OL' OutLaw's Avatar
oil is oil, slick is slick.....worry about it in about 3,000 miles....
oil nowdays is meant to be able to be mixed with other oils....it won't hurt a thing.
I will say this....my truck doens't do ANYTHING but tow...and in MY particular case, I would drain it
and refill it with the proper oil....if you're not towing 100% of the oil change, FUGGEDABOUDDITTT
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
