Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
Old 01-09-2008, 03:55 PM
HillBillyDelux555 HillBillyDelux555 is offline
Send a message via AIM to HillBillyDelux555
Will Zoodad work on Early 99?
Will a Zoodad mod work on an Early 99? where it the intake "thingy" at the grill, I saw the hole by the intake but couldnt follow it. Does it help any on the Early 99 model? Thanks
Old 01-09-2008, 03:57 PM
redstroker_2002 redstroker_2002 is offline
KVFD
cuz u have the afe you wont have to worry about that tube. just find the thread about the zoodad that shows good pics and its pretty easy!
Old 01-09-2008, 05:36 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
If you already have the AFE stage 2 then you need to do the mod. My trucks intake temps dropped 80* with putting on the AFE and zoodad mod.
Old 01-11-2008, 03:12 PM
What is all of the supplies you need to do the ZOODAD MOD?
Old 01-11-2008, 03:18 PM
07OUTLAW 07OUTLAW is offline
Never been banned!!!:)
socket / ratchet, or wrench (not sure the size) and a flat tip screw driver.
These are to remove the grill.
Dremel with cutting wheel
To cut the hole
That's it
Old 01-11-2008, 03:22 PM
sevenmalards sevenmalards is offline
Take 'em on this pass!
To cut the hole
That's it
I just drilled a hole in each corner then cut mine with a sawzall.......she ain't going to win any beauty contest but it works just the same!
Old 01-13-2008, 08:31 PM
samiam samiam is offline
Living on a prayer
when i installed the updated stock ford air intake onto my early 99 I found that there was a thick flap of rubber material that the front of the intake square tube shoved right up against. i guess it was there in my truck since my truck had the original airbox and no tube pulling air from up from. i just had to remove that rubber material, and then put the hole in the grill.
Old 01-14-2008, 05:46 AM
powerplant powerplant is offline
"""""SCRATCH"""""
I always thought it would help are early 99s just to get more cool air into the engine compartment the only concern i have is that later models are putting air in a tube to the box. But were going to be putting alot of cold air in the winter on that battery on that side.I might be over thinking this im going to go ahead and do mine .Good luck.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
