XLE8 Upgrade or not - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-01-2013, 06:18 PM Thread Starter
XLE8 Upgrade or not
I currently have my injectors at Rosewood's getting some 160/100 made and then I will be doing a D66 turbo along with some other supporting mods. I was doing some research on the different PCMs and I found alot of older threads from a couple years back that said to upgrade to a 2000 or 2001 PCM. Is this still something that you should look at doing or is it not really valid anymore with today's tuning. I will be having PHP do the tuning and I have the option to pick up a PMT2 locally for $100 and didnt know if I should do that now or just tune for the XLE8
cory99 is offline
post #2 of 3 Old 04-03-2013, 06:35 PM
Redlazer's Avatar
I'm interested in this also. Hope some one had a few answers.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #3 of 3 Old 04-05-2013, 09:18 AM
03machstock's Avatar
Dont know about automatics because i know there are certain things to make them shift better/ firmer and whatnot, but when i asked tuners about updating my pcm in my e99 6 speed, they told me not to waste my time. Hopefully someone else can chime in that knows more about autos.
Hope this helps
e99 F-250 Regular cab lariat 4x4 manual transfer case, 6 speed 7.3
Warn Premium Hubs
Isspro ev2 Pyro and Boost
6637
MBRP 4" with muffler
Rigid D2's
03machstock is offline
