Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
Old 01-01-2008, 01:27 PM
a1l71700 a1l71700 is offline
Angry Go Pedal Ghost
I have had a bit of an irritating problem that comes and gos: Sometimes under normal accelration/steady speed my truck will lurch. If I try to hold a steady speed at say 20mph it is very noticable. If I continually depress the accelerator it will not do it. At high way speeds it is much less noticable. The best I can explain it is if I press and hold the pedal in the same spot just driving in town it doesnt respond, then it does, then it doesnt and so on. And mean while you are getting jerked back and forth in the cab.
Any takers...?
Old 01-01-2008, 01:36 PM
redstroker_2002 redstroker_2002 is offline
KVFD
cps?? do u wanna sell ur tw???
Old 01-01-2008, 01:40 PM
red73psd red73psd is offline
az powerstroker
gas pedal assembly mine went out recently replaced it. worked fine now its doing it again
Redstroker that was what I was planning to go with but instead went with a 6 pos.
Old 01-01-2008, 01:41 PM
red73 is there a recall on this?
Old 01-01-2008, 01:44 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Yeah sounds like the tps or throttle position sensor. I have a link at home that sells just the sensor and not the whole pedal assembly that ford sells. I will post it up when I get out of work tonight
Old 01-01-2008, 01:45 PM
No recall on the tps, but on the cps or cam position sensor yes there is a recall
Old 01-01-2008, 01:46 PM
Here read this threadCMP recall
Old 01-01-2008, 01:48 PM
vitalidle that would be great if you could post the link. It is a very annoying problem.
Old 01-01-2008, 01:49 PM
You bet its like 50 bucks for the sensor vs 180 for the whole assembly I think.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
