Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L General Discussion > Early 99 Discussion
  #11 (permalink)
Old 12-18-2007, 10:41 AM
REDPOWERSMOKER REDPOWERSMOKER is offline
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
MINE IS A EARLY 99 AND I HAD THE FOIL ON IT SO I TOOK IT OFF TOO MAKES A LITTLE MORE TURBO WHISTLE IN THE CAB AND ITS FANTASTIC
  #12 (permalink)
Old 12-18-2007, 10:42 AM
Originally Posted by hondo997.3 View Post
would be hard to do diy stg 3 hybrids
im stil in high school and not extremely qualified
just wanna know
thanks
I DONT THINK IT WOULD BE TOO HARD BUT IM GONNA DO THE STAGE TWOS AND IF I GET THE BIGGENS THEN I JUST BUY THE WHOLE INJECTOR ALREADY COMPLETE JUST DROP THEM IN AND OFF I GO I HELPED A FRIEND OF MINE REBUILD HIS SO I THINK STAGE TWO AINT MUCH DIFFRENCE
  #13 (permalink)
Old 12-18-2007, 11:00 AM
benderado benderado is offline
I know that a *17 HPOP will provied enough fuel for 230cc hybrids but not sure how a *15 would hold up.
  #14 (permalink)
Old 12-18-2007, 11:07 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
If you keep the hybrids 200cc or lower then the 15* should do fine. But with 230's, you need a 17*. I been doing some home work lately.
  #15 (permalink)
Old 12-20-2007, 11:56 AM
OK THIS IS A QUESTION IVE BEEN WANTING TO ASK BUT THOUGHT I WOULD RESEARCH IT FIRST REALLY CANT FIND ANYTHING WHAT DOES 15* STAND FOR AND WHAT DOES 17* STAND FOR AND WOULD IT BE SMART IF I DECIDE TO DO THE TURBO INJECTORS JUST TO GET A TWIN HPOP???
  #16 (permalink)
Old 12-20-2007, 09:48 PM
the 15*(degree) means the angle of the swash plate style pump. The 17* is a steeper angle of the plate so it flows more oil per revolution.
Here is a pic of the 17* fixed angle swash plate in the pump without any pistons
There are more pics here to help understand the parts and pieces: HPOP disassembly pictures from trucks photos on webshots
Big oil will always help bit it is $2K. What injectors are you thinking of putting in your truck?
Keep Strokin'
  #17 (permalink)
Old 12-20-2007, 09:55 PM
I also found this prettly little picture
  #18 (permalink)
Old 12-20-2007, 11:38 PM
scoobywrx05 scoobywrx05 is offline
Good find Howard.
  #19 (permalink)
Old 12-21-2007, 05:52 AM
Well had some stuff taken care of got a little extra money to put on truck unless something comes up but was planing on big oil stage two injectors for diy-injectors.com and a d66 with a t-wildman chip just being careful my moter does have 205,xxx on it and i just kinda been being careful with it dont want it to blow
  #20 (permalink)
Old 12-21-2007, 07:09 AM
With stage 2 single shot injectors I would not waste the money on big oil. You HPOP can be rebuilt to a 17* for $450 by Bob Riley (dieselsite.com) and you will be good to go.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
