Need help with external tank - Ford Powerstroke Diesel Forum
Old 12-16-2012, 03:49 PM
dpt dpt is offline
I just bought a 100 gallon fuel tank from a semi. need suggestions on how the best and CORRECT way to plum to existing tank in truck. Thanks for any and all help..
Old 12-31-2012, 05:01 AM
dpt dpt is offline
Any help at all?????
Old 02-09-2013, 02:21 PM
I would plumb it into the vent line, b/w the hose and metal line from fuel cap. You'd never have to open you're fuel cap again, as long as you have A BIGGER AIR LINE ALLOWING AIR TO ENTER THE TANK
Sent from AutoGuide.com App
Old 02-10-2013, 05:45 AM
i would "T" it in to existing oem fuel line b4 fuel pump, with a 3-way valve.
Old 02-10-2013, 06:13 AM
RDS Diesel Install Kit for Auxiliary Diesel Fuel Tank — Fits 1999–Current Ford and Dodge, and 2011–Current Chevrolet and GMC Trucks, Model# 011025 | Auxiliary, Transfer Skid Tank Accessories| Northern Tool + Equipment
That'd be the only way I'd do it.
Old 02-10-2013, 06:52 PM
I have used this particular kit.. works great. Otherwise a direct drain into one of the capped vents on your tank would work as well.
Just make sure you have a valve plumbed in for safety.
