e99 ??
Okay I am going to swap pcm,I ecm or what ever you want to call it..Question is will a 02 pcm work and if is doesn't all I will have to do is take it to ford for a reflash???I did find one of the 01 with high trans pressure.. For $250.00 or I can get a 02 for alot less..Both are autos...
I have read alot of posts and there is some grey area one the matter.. Jason |
they should interchange without problems it all depends on whether the PCM that you use has the same options as your truck. I have one from a 2000 in mine and the only difference I have found is that the newer trucks had an intake preheater and I get codes for that since the computer can't find one, E 99 and 99's did not have a preheater. A lot will depend on if you have a chip or stock. If you are chipped the chip will have to be sent in to be reprogrammed to the newer computer.
