Power window problem
The other day my windows decided to stop working so now im kicking my *** every time i fart inside my truck. I own an early 99 f250. Any idea which fuse might be causing this? i tried looking it up but no luck.
Could be the switch or window motor just a suggestion look n the owners manual?
Sent from my C771 using AutoGuide.Com Free App |
Dont have a manual. But its weird that both motors broke at the same time dont you think? Thanks for the input though
Have you tried just using the passenger side switch alone?
None of the switches respond
Is your radio working or not?
In my 05 F350 V10. All the windows stop working accompanied by the radio not working. It goes on and off all the time though. It has to do with the accessories delay relay not being energized by the PCM, or whatever controls that relay. Its a real pain and I haven't found a solution to it yet. |
Radio works just fine
It is a big green 30amp fuse under the hood. I cary a couple of spares, 'cause I fart a lot.
Degnol you the man! Do you happen to know which number fuse it is?
Fuse/relay box in front of the firewall, three rows, middle row, 5th fuse, counting from front to back. In my truck it is the second 30 amp.
