pcm needed - Ford Powerstroke Diesel Forum
Old 06-06-2012, 03:51 PM
pcm needed
Chipped my e99.....started but no change between settings...was told pcm prolly has a program in it so I need a good stock pcm... awa 3...anyone have one they would sell call or text 270-952-3161 thanks...Ford said they could reflash it but no gaurentee it would work
Old 11-01-2012, 09:46 AM
I have an awa1 I think for a manual, already reflashed., I put one out of a 2000 in mine so that it could be manipulated easier with custom tunes. the only difference is that the 2000 and newer had a preheater so I get a code for that but no check engine.
Old 11-28-2012, 02:54 PM
you might check the port where the chip is plugged into. a lot of times the contacts are not cleaned off enough.
