high egt's and low power - Ford Powerstroke Diesel Forum
Old 05-22-2012, 03:59 PM
Drivin jus my truck pullin nothin i run 800 degres at 55 mph and it seems like i have no power wen i gas it my boost pressure is still the same ...my camper weighs 9000 lbs and i run 1100 degres .. need some help
Old 05-23-2012, 09:52 AM
might check your backpressure valve. Sounds like my issues before I replaced the tube and sensore 2 years ago, then this spring the valve itself started to stick so I just deleted it. Best thing I ever did.
Old 05-23-2012, 11:00 AM
What is the boost level that stays the same?
I would guess the ebpv also unless the air filter is plugged up.
Any smoke?
Old 05-24-2012, 03:26 PM
I wired my ebpv open aint got the money rite now for the delete ... n my air filter is a brand new 6637....but my boost always has maxed out at close ta 30 n it there is the same amount of smoke
Old 05-24-2012, 05:15 PM
How are you running 30 lbs of boost? You would need a turbo and bigger injectors.
And, i really hope you aren't seeing 30 lbs while driving at 55 no load!!!
This would indicate a major problem.
Old 05-24-2012, 05:38 PM
No no i missunderstood.. i run bout 4-5 psi at 55 mph
Old 05-24-2012, 06:51 PM
Ok, in this statement, are you saying that the top boost limit is still the same as before you had this problem?
First thing i would do is try and verify the temp reading with another gauge.
800° seems hot for a 55 mph cruise and 4-5 psi.
How bout some more details about your truck.
lift, tire size, what is stock or not stock, auto/manual?
This might give us a little more understanding. Also what gauge are you using?
Old 05-24-2012, 08:18 PM
My top boost hasnt changed , thats y idk its sluggish. N i am usin autometer phantom 2 gauges also my truck has 3 inch lift and 305s. But i had 35s n it read low
Old 05-25-2012, 07:24 AM
Do you have a chip or anything?
I always thought a stock turbo wasn't gonna give you 30 psi regardless of the tuner.
We need to know quite a bit more about your truck man.
Old 05-25-2012, 08:13 AM
I have a ts 6 position 4" exhaust to a single 7" stack. No matter if i put it on the highest settn or stock i still run round 800°. It started about a month ago
