When does it end? - Ford Powerstroke Diesel Forum
Old 05-04-2012, 10:58 PM
When does it end?
I tell ya it has not been cheap, I bought my early 99 last April knowing it had problems but I wish I had done a little more research first. This beast has hit pretty much every issue people have had short of shut down no restart. (knock on wood) just on the engine, I replaced the starter, alternator and riser pipes last year but in the last 3 months I have had to replace the injectors, the entire A/C system, both manifolds and riser pipes, water pump, idler pulley, tensioner assembly, valve cover gasket/wire harness, fan blades and head light buckets. Soon to be replaced will be the hpop, cps, fpr and power steering pump. should be a new rig by the time I get done.
Old 05-04-2012, 11:46 PM
how many miles? sounds about like 150k-200k
Old 05-05-2012, 11:07 AM
actually it has 317,xxx on it, everything seems strong. It came with a 60hp superchip and I have swapped to the ford AIS intake, just did the zoodad behind the grill and the boost fooler. so far the improvements have helped a lot but I will know the true results when I get the new hpop on and fpr rebuilt.
Old 05-13-2012, 03:34 PM
You will be good for another 150k once your done lol. I would put a coolant filter kit so ur not doing water pumps all the time there like $109.00
But u have fixed almost everything so atleast u know nothing will break for a while lol (knock on wood)
Old 05-13-2012, 05:21 PM
theyre 109? mine was like 115 from autoclone with a lifetime warranty... jmo lol
Old 05-13-2012, 06:11 PM
109 and diesel site
At **
Old 05-15-2012, 09:58 AM
I will look into it, the stock water pump made it over 100k before it pooped out, may have been stock. But a filter kit would be nice and I can get the filters that have the additive in it.
Old 05-18-2012, 02:27 PM
What is the boost fooler?
Old 05-18-2012, 04:39 PM
I found it on ebay. what you get is an inline vacuum booster (I think) that goes in line between the map sensor and the turbo Y-pipe. also you get a plastic vacuum splice with a hole drilled in it that attaches to the waste gate valve. The concept creates a vacuum relief at the waste gate holding it open longer allowing the turbo to spool up quicker and longer, it also helps to reduce black smoke. although it is supposed to "fool" the map sensor it still throws a code for excessive waste gate something.
