help me out guys!! - Ford Powerstroke Diesel Forum
Old 04-28-2012, 07:54 PM
help me out guys!!
so my truck started doing this thing where if i start my truck i cant drive it unless its completely at operating temperatures.. if i try to drive it cold or a little less then operating temps it will die and is hard to start.. i also have a little bit of a rough idle.. what do i do!?!?!
Old 04-29-2012, 11:00 AM
I never heard of that one I'm sure someone will help out I wonder what it is
Old 04-29-2012, 11:06 AM
i know i had this problem with my 7.3L there was like a thermostat gauge on the exhaust with some sort of flapper thing on it, i would have to let it warm up for 30+ min, same thing wouldent go unless warm and would die, finally i found where it was then wired it open
Old 04-29-2012, 11:27 AM
Alright so I changed my oil and fuel filter and it fixed the problem! Also made my injectors alot quieter! But when I was changing my fuel filterthe gasket wasnt on right and I went to start it and diesel went shooting down the front of my engine and now it makes a huge squeel noise when I hit the gas pedal.. Sound like the belts.. Will this dry up and go away or is this something else I have to fix??
