spyder boots & intercooler pipe boots - Ford Powerstroke Diesel Forum
Old 03-05-2012, 06:33 PM
I was doing the DIY intake mod and noticed that all my intercooler boots are oily,dirt stuck all over them and so are the spider boots at the bottom. I removed them, the clamps where pretty loose, 1/4 inch ratchet very little effort. My question is, should I replace all of these boots or just clean them up and reinstall them. IF they need replaced should I go to a dealership to buy them, or does somebody make aftermarket ones that are better?
Old 03-05-2012, 09:03 PM
Clean them up a bit and see if there are any cracks. I would personally go aftermarket. There a multiple vendors on here that sell them. When I replaced a cracked one it was way to much $$ at Ford.
To help keep them clean, to some research on the CCV mod.
Im sure the guys will chime in with more links. Good luck!
Old 03-06-2012, 11:40 AM
If you reuse them spray the pipes with a cheap hair spray, that way they wont blow off.
Old 03-06-2012, 05:12 PM
thanks. I will do the ccv mod, and try the hair spray trick
