The fog light switch is there...or is it? - Ford Powerstroke Diesel Forum
Old 01-20-2012, 10:05 PM
On my e99 u can pull the switch out when headlights are on but theres no fog lights on the truck ... What r the chances of being able to put some fogs in and have them work off that switch of the truck (to the best of my knowledge) didn't come with fog lights. Thx
Old 02-10-2012, 03:29 AM
You will have to get a newer switch.
Old 02-14-2012, 11:55 AM
Well if it pulls out the switch may work its the question of if the wiring harness for the lights is there or not.
Old 02-14-2012, 11:59 AM
I would imagine the harnesses may be the same, they just didn't hook up lights to your truck. I could be wrong about that.
Are you the original owner? If not, could the PO have taken them off? Just asking.
Old 02-14-2012, 12:41 PM
My original switch pulled out but it didn't have any power. Had to get a newer one.
Old 02-14-2012, 12:43 PM
Powered by Deez Nuts
haha manually wire em like i did.
the pull put still doesnt do anything.
Old 02-15-2012, 04:40 PM
When you're saying "newer switch," what year should I look for? Can I just pull a switch, harness and lights from the junkyard and I am good to go? My 99 didnt come with fogs and I want to add them asap.
Old 02-15-2012, 05:01 PM
i dont know if it is even wired for it.
Old 02-24-2012, 10:10 AM
I got the wiring harness from Ford when I got the switch.
Old 02-24-2012, 11:43 AM
Where do you plug the harness in?
Autoguide....posting when I shouldn't
