Options for Track Bar with 2-4" lift?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-17-2012, 11:57 AM Thread Starter
99F250SD7.3's Avatar
I think I've read that the e99 bracket and axle mount can be drilled out to fit the later model adjustable track bar, since it seems like no one makes one for the early 99. Is that the best option to center the axle up? What's everyones input on this that has a lift? I need to fix mine asap as I have some popping sounds sometimes going over bumps in the road.
Thanks,
SOLD - Early 99 7.3 4x4 ECLB F250/35" General Red Letter Grabbers on 18" Eagles/DIY Intake/Leveled/HPX/4" TB exhaust to 5" tip/Glowshift gauges/PHP Tunes
99F250SD7.3 is offline
post #2 of 6 Old 01-25-2012, 08:43 PM
SLO_F-250's Avatar
Quoted: 9 Post(s)
I did a 2 " leveling kit and fabbed up my own track bar. One end had a bushing, and the end that bolted to the axle had an adjustable heim in it. Worked like a charm, but for a 4" lift youll have to to a drop bracket of sorts Im pretty sure.
Early 99 7.3L F-250 CC 4x4 (Build Date-02/98) - 212,xxx miles
DIY Intake with S&B Filter, FBD 4" Exhaust, leveling kit, 285's, Mag-Hytec Diff Covers, 203* Thermostat, CCV Mod, Glowshift Gauges from Stealth, Dieselsite's Coolant Filtration System, and Bilstein 5150's, Warn Hubs
Driven Diesel's Hutch Mod in the garage.
DP Tuner on the list next!
SLO_F-250 is offline
post #3 of 6 Old 01-26-2012, 04:53 AM Thread Starter
Right now I have the 2" mini spring pack, but would like to get rid of it in favor of 3" hangers.
post #4 of 6 Old 05-19-2012, 02:12 AM
JMM_MD's Avatar
Thanks,
I just did this mod - installed a 2.5 leveling kit and an ICON adjustable track bar/Pan Hard Rod. On the early 99 you will have to drill out the mounting brackets with a 3/4" drill bit to get that mounted up.
See Ya!
JMM_MD
00 Exc.
99 250SD
JMM_MD is offline
post #5 of 6 Old 05-19-2012, 08:06 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I modified my factory track bar on my early '99, as I had just replaced it less than a month before I added a leaf to the front of the truck... track bar was about half an inch too short, so I chopped it in the middle, and found an old jeep front drive shaft I had laying around, the tubing was the right inside diameter to sleeve the track bar, I cut some splits/wedges in a 8-9" peice (so each end looked like a kings crown), for more welding suface, and welded it up right where it needed to be... worked great.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #6 of 6 Old 05-20-2012, 02:41 AM
JMM_MD's Avatar
Interesting!
See Ya!
JMM_MD
00 Exc.
99 250SD
JMM_MD is offline
