Hey guys my truck has been running bad and it looks like Im going to need some injectors. If I buy a new set for my e99 would I be able to run a set of stage ones or hybrids with my stock hpop and the rest of the truck being stock or should I just stick to AB or AD injectors if I dont want to have to upgrade everything else to go with the injectors.
Also if somebody can explain the whole injector thing I am new to it. I am not looking to make my truck a race truck or spend boat loads of money on it, I just figured that if I had to put new ones in for the little bit of extra money maybe I would upgrade a little bit. Also what set is best for fuel mileage? Thanks Guys! |
There are plenty of recomendations on here for injectors. I have looked at rosewood and full force diesel.
I can get a set of full force diesel injectors for about the same as rosewood and get a better warranty. |
if you dont want to have to change anything then go with ab's, ad's are more oil hungry than ac's and flow 20cc less fuel
If your truck is essentially stock, then ABs are the way to go.
