rebuilding a turbo, take a look and let me know! - Ford Powerstroke Diesel Forum
Old 10-09-2011, 06:10 AM
had some issues with the truck recently, flange came off ripped the EBV valve out and broke the downpipe! bougth a non-ebv pedestal and gutted the flange. turbo had some slight play so decided to get a rebuild kit. took the turbo apart and found some marks on the turbine wheel. I wonder what they are, maybe thats how they balanced it or sumtin. truck has some 240K miles and as far as I know turbo is factory. I also found out that two bolts that hold the center section to hot side are missing, one is loose and only one is holding it. I have another 2000 truck and power difference is night and day. I hope that once I rebuild the turbo and put it all together I will get the power back thats missing. truck felt like it was lazy and it would only boost at highway! Im gonna do a leak detection too just to make sure im not loosing boost anywhere!
btw my trucks are international and they come with very nice freeflowing 3" downpipes!
I have no boost gauge and im gonna put a VDO gauge. im drilling in the Y-pipe, does it matter where do I put the fitting?
thanks for the help
Old 10-09-2011, 06:19 AM
Used to balance.
Old 10-09-2011, 06:58 AM
VDO gauge?
I'm guessing the drilling means for an EGT probe?
If so, put it in the manifold. Post turbo temps can be somewhere up to 500* less than manifold temp.
Old 10-09-2011, 07:20 AM
vdo boost gauge, sorry typing on the run! I read to drill in the Y-pipe and put the fitting in there. does it matter if I put it before IC or after?
Old 10-09-2011, 07:28 AM
Oh gotcha.
No. Does not matter. Some put a bung on the IC tubes, some just tap the map line but that can flutter sometimes for some people. But drilling and tapping the spider is most common.
Old 10-09-2011, 07:30 AM
I would do it after so it is what the engine is actually seeing.
Old 10-09-2011, 09:10 AM
No, intercooler has nothing to do with boost (unless it's leaking.) As long as it's after the compressor side of the turbo and before the heads you're good.
Old 10-09-2011, 10:31 AM
thats what I was thinking it too, incase of a boost leak I would be able to tell if there is any if my gauge fitting is after the IC. Im not sure what does IH have their engine setup as boost goes? I know they had 170HP version but dealership can update it to 230HP I think.
Old 10-09-2011, 10:39 AM
The IH version? Not sure.
A 2000 F350 (08/99 engine) has 215HP and 430TQ IIRC. The stock Garrett turbo can handle up to 30PSIish.
Old 10-09-2011, 04:50 PM
so a 30PSI boost gauge is more than enough I think? I was told that dealership can tell me which HP version my truck is. step van makes it easier to work on turbo since its very accesible from inside the cab!
