I have a e99 f350 cclb with a 12" lift on 40s.
its straight piped and has a edge programmer.. i know the basics like a hpop turbo injectors n so forth.. i want to build the engine up over time and my main question is what should i do in a spacific order to build it up.. if you were in my position and wanted a badass 7.3 what steps would you take |
Get rid of the edge, and get custom tunes.
Tony Wildman Performance Chips And you get free re-burns for when you add mods in the future. |
Do you have 3.73 gears in that?
whats your goal/budget
Sounds like you'll be needing to save money for a new transmission if its an automatic :-) Just a warning.
1) Custom tunes like mentioned before
2) Turbo, either 38r, WOP GQSSB, or S366. 3) Regulated Return 4)17* HPOP 5) Trans upgrade, BTS 6) Stage III hybrids 238/100. That should do ya fairly good, probably around 450 hp, Didn't really say what your goals are. |
Mod your IDM.
my first thought is have you re geared the axles? that alone will give you a good power increase.... but most people dont like doing it because it costs a good amount of money.. .after that get some custom tunes....
Drop her down some and put some 35s..thatd prob help immensely.
I think they are 373s.. Whatrver stock is for the 99 f350... I dont really have a budget because im doing this overtime not all at once. Do u guys think I should upgrade the the 99.5-03 stuff before getting a new turbo or just get one that is a direct bolt on from the early 99 turbo??
