EBPV problem - Ford Powerstroke Diesel Forum
Old 07-15-2011, 08:06 AM
EBPV problem
Hello All,
I am a 18 yr army vet that just bought an E99 F350 Dually with the 6-speed manual...I am new to these powerstroke diesels. Is there anyway to bypass the EBPV under the turbo with a fooler (ie. resistor or etc) if so what size? I have just recently ordered a T500 HPOP for my truck also...a diesel mechanic said that my stock aint keeping up 574 cranking 934 wot.
Thanks
Old 07-15-2011, 08:12 AM
The Tamed Racing Driver
You can just unplug it. Its the yellow, two wire plug with a metal wire clip at the top of the turbo pedestal. It will throw a code, but it is a soft code and wont turn on the light. Mine was unpluged for years cause it would turn on while going down the road
Old 11-13-2011, 12:15 PM
ok thanks..
Old 11-21-2011, 07:15 AM
**** that. wire it to a switch and use as an exhaust brake. hands down the best mod i've done to mine.
Old 12-05-2011, 10:28 PM
is there a thread to wire it up as an exhaust brake? just splice in a switch, or do you need to add power to it?
Old 12-06-2011, 04:00 PM
I drew this up real quick
The colors are not right, but it dosen't matter because the polarity wont make a differance. You have to cut the factory wiring harness and then splice in your wiring.
Old 12-06-2011, 10:14 PM
looks easy enough thanks!!! i wonder if there is a switch i can mount to the floor to use like the old tractor trailers used for their jakes... that'd be pretty handy for the mountains around here... if i tackle that i'll throw some pics up...
Old 12-06-2011, 10:27 PM
Feedback Score: 7 reviews
Get a high/low beam switch out of an OBS! They mount to the floor, and would work GREAT!
Old 12-07-2011, 02:13 PM
Don't get too excited. Mine dosen't work well (really at all) as an exhaust brake. I think the OBS trucks work better for an exhaust brake.
Old 12-07-2011, 03:27 PM
They work fairly well as a exhaust brake. I have done 29k over a few passes and it was defiantly worth having.
