Which HPOP?
Hey guys I have been shopping around for a HPOP. Truck is of course a E99. When ever I am under WOT and I run the Edge EZ it bogs out. So I guess I need some more oil feeding my injectors?
I am looking at the Adrenalin and the Stealth srp1. Any suggestions or comments on the better pump? I am not doing anything crazy to the motor. I just want the power when I need it. Other wise the truck runs and drives great, but as soon as I have any kind of chip like the Edge EZ(currently out of the truck) or the 5.6k mod turned on it just cannot keep up. Any input would be appreciated! |
I doubt its the hpop I would think its going to be in your fuel system somewhere. Have you changed your fuel filter?
So you think it could be a fuel problem? It only happens under WOT. Other than that the truck runs great and gets 19.5mpg city and 24mpg highway. I would not even know where to start if its a fuel problem. fuel pump? or the pick up in the tank? The truck has 205k on it now. |
I'd check with a scanner for codes and see what your HPO is at WOT.. I don't see that you have a boost fooler..that could be the problem. If you need a HPOP..SRP1..its in a class by itself..
I would suggest removing the Edge and the 5.6k and 2.2k resistors and get a TS chip with custom tunes.. |
I DO NOT have the Edge EZ hooked up right now. The 5.6K resistor is on a switch so that is not on all the time. This no acceleration problem only happens when I am under WOT and the resistor is on or the edge is hooked up. I was thinking about the custom tunes, but if I still have this problem with the tunes, which I think I will, then I just spent money on something I cannot use. So its a tricky situation. I need to see how I can get a good scanner and check the codes. Im probably ganna need to take it into a shop because I do not have a scanner that can work on our trucks Thanks for the help so far! any more info is greatly appreciated! I need to get this bug worked out |
Get yourself a used Snapon MT2500..usually for $200-300..will read codes-clear-read HPO, buzz tests...etc..
Do I need any special cartridge? I see there are different adapters and stuff. Anything specific? Last edited by 45_ACP; 07-07-2011 at 01:26 PM. |
what about AutoEnginuity? any good for running diagnostics and pretty compatible with our trucks?
Who are the best people to deal with to get a TS performance 6 position chip?
