Air Filter - Ford Powerstroke Diesel Forum
Old 06-30-2011, 07:48 PM
Air Filter
I was told only a few different aftermarket filters will work on the early 99 PSD, could you guys give me a few that will fit, don't want to make a 250 dollar mistake. Thanks
Old 06-30-2011, 10:50 PM
JEL JEL is offline
I believe there are Tymar/DIY, AFE, and the AIS. I would personally go with the AIS if you're not planning on going over about 400hp or so. It will outflow the stocker and nothing can match its filtration. A Tymar/DIY intake will work, but you'll be a 45 degree angle peice of 4in pipe to make the curve, also be sure you use the water resistant Donaldson air filter if you do go that route. I don't have the part number handy, but if you search around you will come across it.
Old 07-01-2011, 02:04 PM
Feedback Score: 5 reviews
We can get you a Tymar..get me your zip and if you have a steel battery tray..if your interested.
Cary
Old 07-01-2011, 04:27 PM
I was thinking about getting this...Airaid Intake System 400-246
Old 07-01-2011, 04:47 PM
do it like i did, get intake tubing from a 99.5-03 and swap it, then do the DIY intake.
Old 07-03-2011, 09:57 PM
I just removed everything the battery box (cut it up so it still holds the battery) and put in the filter and used ABS pipe all the way back to the CCV. Still had to use a 45 degree and a long pipe and it fits super tight but its all up to you. get the filter you want and make it work is my style
Old 07-09-2011, 05:09 PM
I agree you can put anything you want in, just depends on how much you feel like doing yourself.
Old 07-15-2011, 08:04 PM
I was talking to a guy about his AFE filter and he said that sometimes there is a problem with it trying to push to much air through the pipes after the turbo actually restricting the air, so those pipes (whatever theyre called) can be upgraded another inch to let that air through.
Ever heard of this?
Old 07-29-2011, 07:33 AM
Boot, scoot and boogie
or do what i did.. this is my E99 intake, and no its not a tymar
Old 07-29-2011, 11:13 AM
Riffraff diesel has them for around 60 bucks. The 45* pipe, filter, clamps and a filter cover in your choice of color
