Which IDM to get?
As I posted separately, I recently became a proud owner of an E99 F350 dually. I had some injector (or what i thought) issues so I bought AE to diagnose.
AE came in today, I fired it right up and ran the injector buzz test. All injectors buzzed and they all sounded very much the same, but test came back with P1298 IDM Failure. Then I ran the KOEO test and got 3 codes back: P0230 - Fuel Pump Primary Circuit P1298 - Injector Drive Module Failure P1690 - Wastegate Solenoid Circuit I do know the previous owner put in an aftermarket fuel pump so i suspect that is where P0230 is coming from. The other two I am more concerned about. The P1690, seems like this would also be unrelated to the IDM, but I'm going to track this one down first just to make sure. I think this is easily remedied as the solenoids are cheap even if i have to replace one. I think P1298 explains my suspected injector issue so I'm looking at replacing the IDM. As I understand it that is one thing they switched from the E99 to 99.5. I see these on ebay for relatively reasonable money. Does it make sense to go to a 120V over the 110V IDM? That is, can I expect better injector compatibility with a 120V one? Will I run into any issues? |
Go with the 120 all the way, every thing is the same, unless you want to get a modded 140v one, that would work too.
