Nominal EGT
I'm adding things daily to my new e99 F350 DRW and I'm getting some interesting observations now that I have my EGT gauge hooked up.
Stats: PHP chip, set to 80hp daily driver. This is supposed to be an economy setting. The truck has a 4" exhaust, but unfortunately I had to have a cat installed. EGT probe is installed at the back of the driver side manifold. So on my test drive I was getting egt temps around 350° to 500° just toodling around my neighborhood, keeping speeds under 40. Then I got on an open stretch of road and kicked the speed up to about 60, but not an aggressive acceleration, about the same as getting on the freeway. Temps got up to 800° to 1000°. Then I went up the steep hill, WOT and got up to about 80 mph. The egt shot up to 1,420° but dropped down into the 1,300°'s when it got into 4th gear and the TC locked. My only concern is the temp spike with no load. I'm going to throw a heck of a lot tougher workload at it when I get to cutting wood. I'll be towing a 16' trailer and going up a long and very steep winding mountain road. Now for my test tonight I left it in the 80hp daily driver setting. Will my temps be better controlled when I'm towing heavy loads and have the chip set to one of the towing settings? What's the highest I should let the exhaust temp get to before I need to intervene? I put an aftermarket cat and the exhaust shop said that they type I put in isn't prone to clogging, but I'm not so sure it isn't contributing to the higher temps. I had it welded in but it's going to have to come out when I put the exhaust brake on so I think I'm going to go ahead and punch it out and then have it welded back in. The smog guy shouldn't be able to tell. I think all they do is a quick visual look for the bump and nothing more. Is there any other way for them to tell? Thanks, The |
Yeah, that does seem pretty dang high.
How far in is the probe itself? In the middle of the manifold? How much boost were you pushing when it got that high? I have a similar setup, (mods below) and I rarely see above 1200* in the 120 race setting. Keeping it below 1200* is obviously optimal, anything above 1300* will start to fry stuff.
make sure your intercooler is clean, I've seen high egt's when theres a bunch of dirt in them and once you wash them out most of the time your good to go. theres a lot of dirt and wind here in reno as you know. so try that and see what happens.
personally when I come around 1000 on egt gauge i start to let off some, but everyone is different. and with your cat if you just punch it out and weld it back in you should be fine you just need to be under 40% on the opacity test and that isn't hard at all. Me and my friend go to Pro1 off of terminal and mill to get our smog done, he has a 6.0 with egr all blocked off and they didnt notice. its just a quick look. |
Loose intercooler boots, leaking up pipes restrictive exhaust all can be factors as to why your gets are running so high
I think the boost was somewhere between 9 and 11 PSI. I wasn't actually paying much attention to it. I was more focused on the EGT gauge that was flashing red and beeping. I've got appointments today so I won't be able to get into it to look at the boots and the intercooler until tomorrow. |
10lbs? wow thats nothin.. my truck will nail 25 lbs and still not get that hot. definitely check everything over! and gut that cat!
Yeah, if that's all the boost you saw and the EGTs were that hot you surely have some kinda leak somewhere
By Jove, I think you've got it!
![]() Good call guys. Looks like I've got another project to add to the (long) list of projects. Thank you for putting me on the right trail. So now, next on the hit parade, I guess I need to change all of them out, but I'm having a hard time finding them. BD has a set, but they're for the 99½-03 and I've got an e99. I'm guessing there's a difference. Anyone have any idea where I can go to get the set for an e99? Last edited by MKeeney; 06-01-2011 at 11:37 PM. |
I would bet that has something to do with it! Glad you found it!
low boost+lots of fuel= high egts.
i got the same when i popped a boot off lol. |
