4" hanger kit on e99
Looking at doing a 4" hanger kit on my truck. I know I'll need shocks and rear blocks, but I can't seem to find a decent price for an adjustable track bar for an e99 f250. Could anyone help me out or am I SOL? I know Icon makes a "box" kit which includes the track bar and drop pitman for like $400 but Id rather not spend that much if I don't have to.
Is the drop pitman needed for a 4" lift or would the track bar suffice? Any other input is appreciated, thanks! |
I cut mine and extended. Tons of people do this. I totally understand trying to save money when it cones to lift kits. I built everything on my truck because its way to expensive. Sometimes its a pain to leave the trac bar one while installing a lift because it won't let you pull and tug or persuade springs. Once you get your lift on, cut your bar in half. Slide each end into metal tubing and remount. Once its up you can mark it on each end of tube so you can take it off and weld. Really easy and FREE lol. I have 3.5 of lift and dont have the pitman but I would recommend it on 4 but they shouldn't be too much . Try top gun customz . Good luck
Nice, that makes sense, thanks a bunch!
I've heard that you can convert to the newer style track bar by drilling out the holes and getting the proper larger bolts. The reason for this it that you may be able to find an adjustable trackbar for the newer truck used, or ebay, or... you see where I'm going with this...
Also... the newer stock (non-adjustable) track bar on the newer trucks is made out of steel pipe, and the older one seems to be a cast type metal... I wouldn't recomend welding it unless you are good with cast... I would also not just cut your sleave pipe square... After I cut it to lenth and there was sure to plenty of overlap, I'd cut some v-notches in it, as deep as the pipe is in diameter, (to kind of give it a 'kings crown', spiky look) for more than double the availible weld surface. |
I mean if you are just wanting a adjustable bar you can buy one at top gun too or eBay but I was thinkin the trac bar on my 04 would be identical . Mine was solid metal and took like 30 minutes to weld. And cast is kinda hard ( but I'm not a great welded) .
If you doing a 4" hanger kit just get a complete one..you will be time and $$ ahead..Icon's kit is complete.
$2000 is half what I bought my truck for. I'm not looking for the best ride or the best brand name.
I can buy shocks here for a good price. PMF sells hangers for $350 but in reality I could weld my own and save $300. Pitman drops are cheap as well. I can do everything but cant find a track bar. |
Google search for a 1999.5 or later track bar, I know there are some for $100 on up
