buzzing noise???? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-27-2011, 05:57 PM Thread Starter
buzzing noise????
i have a buzzing noise in the interior. not a brake squeal or power steering noise. its like a sick buzzing noise, sometimes its strong and consistent, other times its weak and randomly comes and goes, most of the time it starts when i turn the switch on. The switch has to be on for the noise to happen, turn signals and/or brakes being applied will stop the buzzing, as soon as you let off of the brake or the turn signal or flashers are turned back off, the noise starts right back up. anyone have any ideas or experience with this problem? thanks a lot!!
frye is offline
post #2 of 3 Old 03-30-2011, 06:53 AM
Living on a prayer
What switch is it that you are turning on to get the buzzing started? sorry if i missed it.
Early 99 (7/98) F-350 CC 4X4 AT 7.3L 200K mi - 4" turbo back w/muffler - AFE Stage 2 - PMT1 ECM - DP 40T/DECEL/80E - dual trans coolers - HPX - Fuel CCK - Auto Meter Trans/EGT/Boost - 3.73 - stock tires
samiam is offline
post #3 of 3 Old 03-30-2011, 02:29 PM
JJR
I have had this buzzing sound twice before. First time was when the gpr was bad second was when one of my batteries was going bad. Its was like a disruption in current flow would cause one of the dash relays to buzz.
JJR is offline
