Hi/low injector control press. issue resolved without replacing hpop. - Ford Powerstroke Diesel Forum
Old 03-24-2011, 09:07 PM
Very big thanks to powerstrokehelp.com videos. I did the hpop oil change as seen in the fuel injector maint. video.
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
I used a $10 hand pump from O'reily's and sucked the thickest, nastiest looking oil out from the hpop sump. I did this proceedure twice, and now when I run my race tune, I no longer get the low injector control pressure dtc (check engine code). This saved me a chunk of dough because I was ready to buy a new pump thinking it's not keeping up. Hopefully this helps someone else also
Old 03-25-2011, 08:16 AM
Hmmmmm....maybe I need to do the same thing. That is the round thing behind the HPOP?
That is an excellent link. I watched it all and in the process, answered my question.
Old 03-25-2011, 10:36 AM
Feedback Score: 5 reviews
Oil in the HPOP sump is constantly being replaced by the LOP as the HPOP draws from it to supply the Inj's..dumb-dumb dumb...
Old 03-25-2011, 01:27 PM
Well, it couldn't hurt to replace the oil if it is all sludgy, huh?
Old 03-25-2011, 01:30 PM
If its sluggy in the rez its the same everywhere..
Old 03-25-2011, 02:07 PM
very true. when will Bill realize the HPO system is NOT a closed system.....
goes like this......
oil pan
low pressure pump
high pressure oil pump reservoir
High pressure oil pump
injectors
back down through engine to oil pan
Old 03-25-2011, 04:33 PM
oil pan
low pressure pump
injectors
Just trying to make sense of the hpop circuit. Is there a diagram/explanation of how the low oil pressure enters the hpop, and returns to the motor sump? Also where the intake to the hpop is, then where does the oil, return from the injectors?
The video makes it sound as if there is a portion of the hpop that remains stagnant, so any contamimants settle at the bottom. I pumped out some thick nasty oil, the oil pan oil was no where near that bad. Mind you, this is my first oil change on the truck since I've owned it.
Old 03-25-2011, 05:30 PM
Well not to throw a wrench into things here but don't you guys think maybe there's a possibility that the sludgy oil can get trapped in the hpop sump. It's a thought. I don't know where the lines tap into the sump but if they are both closer to the top then the bottom then that is a good possibility!!
Old 03-25-2011, 05:49 PM
The Tamed Racing Driver
I think it helps out more then people think it does, and the oil dosen't flow through the injectors as well as people make it out to. Its only like a 7cc pump, and IDK how much its geared down off actuall RPM's but It's not flowing that much oil, just making alot of pressure.
