E99 and add-a-leaf leveling kit
so i am thinking of add-a-leaves for the front but question is all the kits for 99 that i see are for late99's not early 99's.. do i just buy them for an OBS or????
I don't sell add-a-leafs but have Hanger kits and mini spring packs both will ride better.
Cary |
hanger kits or different springs will give you the lift basically.
what is better and what can i expect on price?
shackle kit is good and cheaper than a lift kit, 2" Shackle Leveling Kit might need longer shocks/brake lines, I have the mini spring pack and like it, (it's temporary till my tires wear out, then I'm going with 4" springs), but it mounts under the leafs which retains the stock springs/shocks and gives ya 2.5"
Hangers retain the same spring rate and give you 2" of additional compression..so they will ride better. Mini spring packs won't get you additional travel just lift. add-a-leafs change the spring rate ..stiffer and get you additional travel.
so if i go the hanger route, what all would i need to get the job complete?
probably would need new front shocks, brake lines and the track bar bracket or adj. track bar, maybe sway bar end links?
No sway bar links or brake lines are needed just hangers, adj track bar and IMO Bilsteins..
Cary |
i have shackle lifted 2 superduties, nothing but the shackles was needed. i put a 2 inch shackle on my 99 and was advised i needed a drop bracket for the track arm. so i got one and after over an hour of trying to get the bar to fit in the new drop bracket, i gave up and put the original bracket back on. there was only a very minimal shift in the axle. so now i have a drop bracket sitting in my garage...... anyone need one?
