Brass Donuts or Bellowed Up Pipes - Ford Powerstroke Diesel Forum
Old 01-17-2011, 07:06 PM
I am debating between getting the up pipes from international or getting new stock up pipes and using the beans diesel performance brass gaskets. Any thoughts? I wouldn't mind saving a little cash, but I want to make sure the leak is fixed for good. Thanks!
Old 01-17-2011, 07:20 PM
If you get new stock pipes then I dont see why you would have a problem. I just replaced the gaskets and used the old pipes and it paid off cause the leak is gone.
Old 01-30-2011, 09:53 AM
John Wood Nut Swinger
I have put on brass donuts and never had a problem with them sealing, even on used up pipes. I have also taken them off, using a torch, and reused those brass donuts from Beans. I use chevy exhaust donuts, F17250, on my truck and have never had a leak since I went that route back in 06 or 07. I have even reused the same set of donuts up three times and never had a leak.
Old 02-02-2011, 06:35 AM
Are the bellowed up pipes now available for the early 99? When I checked a couple of years ago they were only available for the 99 1/2 and up.
Old 02-02-2011, 07:35 AM
Yeah they are available but I think the cost is close to $900.00 !!!!!
Old 02-02-2011, 08:12 AM
Send a PM to Marty, he has a hook-up on bellowed up-pipes for the early 99.
